HKJ
[size=+3]Vapcell ICR14500 1000mAh (Gold) 2018[/size]
Official specifications:
This is a new generation of high capacity 14500 cells.
The discharge curves tracks nicely and the 3A rating looks to be about right.
[size=+3]Conclusion[/size]
This looks like a good high capacity 14500 cell, it handles the rated 3A current nicely and it do not fall flat if more current is drawn.
[size=+3]Notes and links[/size]
The battery was supplied by vapcell for review.
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Comparison to other LiIon batteries
- Type: Flat top
- Nominal voltage: 3.60V
- End-of-charge voltage: 4.20V
- End-of-discharge Voltage: 2.50V
- Typical Capacity: 1000mAh (0.2C discharge)
- Min capacity: 950mAh (0.2C discharge)
- Weight: Max:23g
- Internal resistance: Max:60mOhm (AC 1kHz)
- Standard Charge: 500mA,CCCV 50mA cut-off
- Charging Time: 3hours(standard charge)
- Quick Charge Current: 1000mA
- Max Continuous Discharge Current: 3A
- Operating Temperature: Charging, 0°C ~ 45°C, Discharging, -20°C~75°C
- Storage Temperature: -5°C~35°C
- Storage Humidity: <75%RH
