The Fenix-Store
Results 1 to 6 of 6
Thread: Batteries not handling turbo for more than a few seconds.. So whats this indicate?
    Default Batteries not handling turbo for more than a few seconds.. So whats this indicate?
    https://secondlifestorage.com/t-LG-L...Specifications
    So I have some LG lgdb318650's I harvested. All of them charged up wonderfully, read 4.15-4.16v after resting, all read 0.0 ohms when tested but when I tried them with my Astrolux MF01 on turbo the light shut off after a few seconds and the indicator on the button went red immediately after going to turbo. On high, the light just keeps ticking till shes red hot.
    So... Is this an indication the batteries being 2600mah can't handle the load? Maybe they're just worn somehow?
    FWIW: My 3600mah Orbtronics just keep trucking.. the light gets very hot at around 1 minute so I backed her down but I wanted to test to see if on Turbo those would run longer and they in fact did. The red backlight was however active a moment after turbo as well on the orbrtonics.
    Modernflame's Avatar
    Jan 2017
    Dirty Dirty South
    Default Re: Batteries not handling turbo for more than a few seconds.. So whats this indicate
    The manufacturer (of the light) recommends 20A cells. My guess would be that those harvested cells are unable to sustain the rather large current draw.
    “May it be a light to you in dark places, when all other lights go out.”
    J.R.R. Tolkien, The Fellowship of the Ring
    Moderator
    archimedes's Avatar
    Mar 2011
    CONUS, top left
    ... moved to Batteries ...
    ... is the archimedes peak
    *Flashaholic* ChrisGarrett's Avatar
    Feb 2012
    Miami, Florida
    Quote Originally Posted by Modernflame View Post
    I just saw on Bangood~USA, it recommends something like the Samsung 30Q, which is a 15A continuous.
    No way those LG laptop pulls can handle anywhere close and frankly, they shouldn't have to.
    I don't really think that the Panasonic NCR18650G cells can handle anywhere close, they're just a bit newer and aren't crashing and burning.
    OP--wrong cells for the job.
    Chris
    Convoy: S2, S2+, M1, M2, Fenix: P1D, PD32, HL30, ET: D25C Ti, SF: 6P, ZL: SC-600, Klarus: P2A, Jetbeam: BA-20, Icon: Rogue 1, L3: L10, Xeno: E03, ShiningBeam: I-Mini, Olight: i3s, SWM: D40A, M11R, V11R, Maglite: 6Ds, MMs, Solitaires, LaCrosse BC-700, Maha C-9000, XTAR VP2, MP1S, XP1, MC1+, WP2 II, NiteCore i4, v2.
    I appreciate the input guys, seems like the 30q are the bees knees for what they are lb for lb.
    ill find a use for these lg’s, got 6 of them.
    MAH is runtime. Amperage is your juice to put it simply.
    hunter, fisherman, flashlight enthusiast
