HKJ
[size=+3]Turnigy Sub-C 5000mAh (Gray)[/size]
Official specifications:
Maximum temperature raise at different discharge currents: 1A:+0,3°C, 2A:+1,0°C, 3A:+1,8°C, 5A:+3,9°C, 7A:+5,9°C, 10A:+8,4°C, 15A:+12,8°C, 20A:+16,4°C
This is a rather unknown battery size for many people. It is used for a lot of stuff, mostly battery packs, but may also be used inside regular C or D cell of the low capacity types. These cells are delivered with tabs, making it easier to use the for packs without a battery welder.
The cells do not match completely, this is not a serious problem with NiMH, the capacity specifications may also be a bit on the high side.
[size=+3]Conclusion[/size]
The cells are rated for high capacity and current, these ratings may be a bit optimistic, but they have fairly high capacity and can deliver a lot of current.
[size=+3]Notes and links[/size]
The batteries was supplied by batteridoktorn.se for review.
How is the test done and how to read the charts
Compare to other AA/AAA batteries: Alkaline/NiMH/Lithium
Compare to other Sub-C/C/D batteries: Alkaline/NiMH/Lithium
- Category: Sub-C
- Capacity: 5000mAh
- Discharge: 10C constant / 15C burst
- Voltage: 1.2V
- Chemistry: Ni-MH rechargeable
- Weight: 70g
- Dimensions: 44x23x23mm
