Test/review of Molicel INR20700A 3000mAh (Gray)
HKJ
Copenhagen, Denmark
[size=+3]Molicel INR20700A 3000mAh (Gray)[/size]
Official specifications:
  • Rated typical capacity: 3000mAh
  • Rated minimum capacity: 2800mAh
  • Nominal voltage: 3.6V
  • Maximum charge current: 3A
  • End of charge voltage: 4.20V +/-0.05V
  • Maximum discharge current: 35A (Cycle life is reduced at high rates)
  • End of discharge voltage: 2.5V
  • Typical impedance: <20mOhm AC 1kHz
  • Cycle life: 500 cycles at 3A charge and 10A discharge for 80%
  • Operating temperature: Charging: 0°C ~ 60°C, Discharging: -40°C ~ 60°C
  • Storage temperature: <35°C, recommended <23°C for long term.
This is a high current 20700 cell.
The two cells tracks nearly perfectly, at the 30A discharge I had to stop due to temperature, but the cell do not look overloaded on the discharge curve.
[size=+3]Conclusion[/size]
Very good battery for up to about 30A, at the high current the battery may need a rest during discharge to cool down a bit.
[size=+3]Notes and links[/size]
The batteries was supplied by N-Power Energy for review.
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
