Can you post which lights you have? I can give more specific recommendations if I know what lights you have.
For example, if one owns a Surefire 6P, it can be converted into a sort of 9P using a Malkoff Devices MD3 body.
On 3/9 I posted a thread regarding the value of two older SF flashlights and my thread was closed. I don't want to sell them. I just want to know if they're worth keeping as is or converting to led. davemp
Folks around here tend to avoid discussing values because Surefire is a status symbol brand much the same way Apple is or Bugatti.
Threads edited and merged, thanks
I wouldn't say that Surefire is a status symbol brand. I would say Surefire is a pretty well known brand and there is certainly brand recognition. For some reason, to me, when I think of status symbol lights I think of McGizmos, Muyshondts, Cool Fall Spys, other various lights with elaborate machining, and at the same time I think of lights with over inflated lumen outputs that are mostly for bragging rights. I don't think of Prometheus Lights, Malkoff Devices, HDS, Streamlight, or Surefire.
For some reason, the fact that I can go to a local store and walk out with a brand new Surefire takes away from the status symbol feeling to me.
....This is the only enthusiast forum that I have participated in where discussion of what your "things" are worth is forbidden....
The E2O uses that 25 lumen bulb that gets long runtimes. It's a really perfect amount of light in my opinion, but that bulb assembly (MN02) is really hard to find nowadays. That light can always use the E2Es MN03...
My plan for my E2E I just got is to use a tads customs adaptor and bi-pin bulb assembly and carry a small container with a spare bulb and a singLED module. Run both on a 16650 and carry a spare cell in my pack. That way I can convert the light from incandescent to LED and back in under a minute, just as easily as I swap batteries.
