Steelwolf
Hi y'all.
Got a question about a conversion I'm planning to make. I have a 4AA headlamp which I would like to convert to LEDs.
I suppose I could always go the easy way and just wack in 4 LEDs in to the PR bulb base and plonk in a dummy battery, but I'm not very happy with that idea. It is not a particularly elegant solution. There will always be an extra battery left from the pack, the light will dim as the batteries grow weaker and the LEDs are subjected to 4.5V which does not do much for their life span.
Can anyone suggest a simple circuit which will take in 6V, buck it down to 3.6V and approx. 120mA (driving 4 parallel LEDs at 30mA each) and keep that output constant? Or deliver 4.0V with unrestrained current, or 120mA and unrestrained voltage. I'm not overly fussy. It can be current driven or voltage driven, or both, but it must keep the output as constant as possible over the life of the batteries.
The further constraints are that I only have what is available from RS Components and **** Smith's Electronics.
Thanks in advance to all. BTW, I'm hoping to get a brightness at least equal to or better than the Princeton Tec Matrix, so if my figures aren't going to give me that, let me know.
