<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Steelwolf:
PeLu: You appear to be the most experienced caver amongst us
<HR></BLOCKQUOTE>
As caves tend to hide themselfes this is not for shure...
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>What would you recommend as a good electric light setup? Number of LEDs, wattage of filament bulb or HID, type of power source (NiMH, alkaline, lithium, etc.), capacity of power source (mAH), should it be dimmable, should the setup be combined LED and filament (or HID) with switchable between either light source? Aluminium or polycarbonate body? Angle of view? Able to focus? Any other specification?<HR></BLOCKQUOTE>
[edit] I just lost much text due to paying not enough attention, therefore I will do it in more parts.
part1:
Actually I've written several articles about that in caving magazines.
1. People are different, cavers are even more. We still have a lot of debates about carbide versus electric lights. As you only ask for electric ones, we skip this question .-)
2. assuming cost is no real argument (actually it is much less of an argument as many cavers think).
3. For expedition use: Only completly helmet mounted lights are useable (cables from helemt down to a powerpack like to catch wall protrusions, thin cables break, thick ones hinder head movement).
Weight should be not more than 400g (~15ounzes) when you use a good helmet. It should be distributed in between front and rear almost equally.
You need about 15-50lm with 20-30° half width (this is about the light distribution you get with a couple of 20° Nichia LEDs), some people prefer a uniform light (like a ceiling burner carbide light or a fluorescent tube), there you need 50-120lm.
You will need also additional light levels. The spacing has to be around 1:4 (1:2 turned out to be too less, a variable setting is useless (but fun to play with)). A brighter setting will be needed for light eating passages, huge rooms and similar occcasions.
Less light will be needed in small passages and crawlways and for most ropework. Even less will be needed for a rest or when you have to wait. The brighter settings should be more focused.
For looking for leads or down pits, a strong spotlight is very useful. An equivalent to an SureFire P60 is the minimum.
For switching in between modes a turnkey is favorable. Just a single pushbutton is not than 'user friendly' (but may accepted).
The complete light has to be waterproof down to 100m (at least). Experience showed, that it is waterproof enough after a couple of years. It has to work also in temperature extremes.
Constant brightness on all settings (maybe except an emergency setting) is a very nice thing.
For the main light, LEDs are the best choice (for relyability and ruggedness). For the spotlight an incandescent may do the job, as it is not essential. For Nichia LEDs, 20-50 should be enough, when the Luxeons come to their claimed efficiency, 2-3 should do it.
Power source: The highest energy density comes in Li D cells, either LiSO2 or Li-Thionylcloride. If you use your light very much, you may think about rechargeables. Lates Li Ion cells are not that far behind the above mentioned D cells (look at at the FX Ion).
IMHO most people overemphasize rechargeables. You have several incertainities. You charger may not work well and even your cells may have a flaw. Actually I've seen many rechargeable lights failing or having a shorter runtime as expected. And it is just not possible everywhere to charge a light. Staying a week underground, several weeks on a mountain plateau or some time in a country with unrelyably mains supply causes some trouble for people with recharegable lights.
(now saving and continuing later)
