Azecos
I have a M@glite 2D modded with an WA ballast wich needs 12 volts. I want to run it on Nimh accu's and it works pretty well, only the light seems more blueish then when i'm using alkaline batts. Pherhaps it needs a little higher voltage than the nimh are giving.
I found a step-up regulator somewhere which has a 12V output.
Can some tell me if this will work?
This is the link: http://www.chipcatalog.com/TI/PT5041.htm
I don't know if the ballast needs a minimal current?
