KevinL
What would you guys choose? A nice big traditional drill, a Dremel, or a third party replacement?
I'm looking at one of these general purpose tools for modding lights, to do the usual cutting, grinding, drilling of holes and associated work that is now done by hand, often in a very.. hmmm.. makeshift fashion (to put it mildly). I'm looking for something inexpensive, so that there's more money to go around for the lights.
I owned a Dremel once, but it has since passed on. Cutoff wheels were notoriously expensive, and I suppose trying to punch through 1mm thick steel in computer cases didn't do either the wheels, the tool, or the operator (yours truly) any good. After a few too many holes, the magic smoke got out of the Dremel, the thing ran really slow and stopped running at all. I thought it would last longer than that.. it wasn't cheap, either. The Dremel would probably last longer doing very light duty aluminium work (some sanding, and occasional hole drilling would be the max, no more steel I can tell you that).
So what would you guys recommend? A traditional drill with cutoff wheels or sanding attachments, yet another Dremel, or some other alternative? Out of all of these I believe the normal drill can be had at lowest cost, of course I'll have to buy the attachments. The other thing about the Dremel besides reliability is that it does not accomodate larger bits for drilling larger holes. I'd prefer something that lasts, not something that quits on me tomorrow.
