PocketMateW. 9W variable output blaster. Thread I.
Status
Not open for further replies.
hotbeam
Melb, AU
It's been waay too long between drinks! /ubbthreads/images/graemlins/grin.gif /ubbthreads/images/graemlins/grin.gif
Over the past year or so, the modders amongst us have been coming out with a myriad of excellent lights. A big majority of them have one thing in common though... they all used a single die Luxeon III. /ubbthreads/images/graemlins/wink.gif Yes, the LuxIIIs have very long lives. Yes, the LuxIIIs can run from lower voltages. Yes, these LEDs are (relatively) cheap. Yes, they also result in smaller flashlights. But where are those beefy Luxeon V mods? /ubbthreads/images/graemlins/grin.gif I want Luxeon V lights!
Introducing... the PocketMate-W.
This light uses the very popular OA2C host, cut down to take either a single Pila 168S Li-Ion rechargable or 2 Lithium CR123As. Total length is 195mm or 7.7inches and it fits in your palm juuust riiiiigght /ubbthreads/images/graemlins/smile.gif. This light uses a boost converter to provide constant current to the Luxeon V LED with W rated flux, binned WX1U to be precise. The light also has a variable output dial perpendicular to the switch just below the head. Output can be varied anywhere between 30mA (Arc AAA brightness) and 1000mA (WOW brightness /ubbthreads/images/graemlins/smile.gif ). UCL lens completes the package.
*** EDIT. Max current will now be set at 1300mA to enhance that WOW factor... making it a 9 WATT monster!!
Here are some photos:
The engine room /ubbthreads/images/graemlins/grin.gif
WX1U Luxeon on the Hotlips just before being soldered.
The Hotlips in perfect contact with the OAC in its permanent home
OA2D, OA2C, PocketMate-W, Miltech (Pelican M6), Arc LS
Light in hand: PocketMate-W
Light in hand: OA2C - 2 C Cells
Light in hand: OA2D - 2 D Cells (MR-X)
The PocketMate-W
The PocketMate-W
Switch it on, adjust the brightness level, use the light. Need to work close range, dial in a lower output. Need to see what is up that tree, dial up the brightness. Switch it off and switch it on again, the light output is where you left it last.
Thoughts. Comments?
*** Run#1 build completed 4 Sept 2004, GMT+1000
hotbeam
Melb, AU
Re: Introducing... the PocketMate-W. Variable outp
Now, what do I do with these? /ubbthreads/images/graemlins/wink.gif
Cost wise, 10 units at the commercial machine shop will cost me $25 to cutdown/thread. 20 units $19. Totally all the bits and pieces and adding some $ for labour/PP fees, the light would go for $175 + $10 post (or $169 if we can get 20 confirmed takers).
Nerd
Singapore
Which boost convertor is it? /ubbthreads/images/graemlins/grin.gif
hotbeam
Melb, AU
It is Fatman powered! /ubbthreads/images/graemlins/grin.gif right back at you /ubbthreads/images/graemlins/smile.gif
hotbeam
Melb, AU
A 3136kb video of the variable output happening in real time can be viewed here.
Beatshots:
PM-W 18 feet from white wall
PM-W 1m from the wall without the head. Photo taken with exposure fixed.
Surprisingly 30mA to a WX1U is very useable, eg as a camping tent light. Should last a loong time in the PM-W.
bajaiman
Sydney, AU
Very nice Howard! /ubbthreads/images/graemlins/thumbsup.gif ... Just when I thought I have enough of Maglites ... Will you be taking orders soon? /ubbthreads/images/graemlins/wink.gif
Icarus
Belgium
Very nice and very usable light too! /ubbthreads/images/graemlins/thumbsup.gif
Where/how did you fix the fatman driver and the trimpot?
Any pics about this?
hotbeam
Melb, AU
bai... /ubbthreads/images/graemlins/smile.gif if there is enough interest, I'll could organise a run. It is just a time issue.
icarus.... the Fatman driver fits in the space betweent he switch and the Hotlips. It is really quite simple. Wiring details are at Georges80 website.
BugLightGeek
St Louis
Any idea on the price? /ubbthreads/images/graemlins/broke.gif
bajaiman
Sydney, AU
I'm interested...depending on the cost tho.... any idea how much this will cost?. Can you use Mag D size body instead of C?
If the price is right put me down on the list! /ubbthreads/images/graemlins/thumbsup.gif
nexro
KL, Malaysia
Very nice light indeed. I am beginning to like all these lights that have different brightness settings /ubbthreads/images/graemlins/smile.gif
Christoph
Hagerstown,Md
I'd Love one of those with a WX1U star /ubbthreads/images/graemlins/grin.gif
Chris
mut
OK
I'm interested again depending on price.
mut
jdriller
New York
Awwwwwwwwwwwwright!
I'm in.
About time, Hottie /ubbthreads/images/graemlins/wink.gif
georges80
Sunnyvale, CA
Re: Introducing... the PocketMate-W. Variable output.
Howard, nice job. Good to see Fatman pushing out the watts!
Yep, dimming/variable lights. I'm a really BIG believer in having that feature in LED lights (whether torches or lanterns). Not having that feature throws away what I consider a big benefit LEDs have over incandescents - the capability to choose the light level for the task at hand without a major change in colour temperature.
When your eyes are night adjusted, 30mA from a LuxV is still a lot of light, just as it is out of a 1W/3W luxeon. As you say, runtime at that level will be excellent /ubbthreads/images/graemlins/thumbsup.gif
george.
Pi_is_blue
Utah
I'm interested depending on the price. This would go well with my MR-X. /ubbthreads/images/graemlins/grin.gif
Any idea what the runtime on high is with 2 123a or the 168s cell is?
jtice
West Virginia
VEY nice work there Howard, and an excellent writeup !!
You did a great job of depicting what the variable output is like,
The size looks great! Seems a good bit shorter than the stock mag.
If we can find a pot, that is alittle smaller, and doesnt stick out quiet as much, that would be niiiice.
Also, the Fatman can be dailed to deliver a good bit more than 1000mA /ubbthreads/images/graemlins/wink.gif
If anyone gets real brave.
Im in for one, depending on cost, or at least a kit.
-John
Icarus
Belgium
[ QUOTE ]
[/ QUOTE ]
Two rechargable Lithium CR123A's = 2x 4.1V = 8.2V /ubbthreads/images/graemlins/thinking.gif
The Fatman driver is a boost converter, using fresh batteries your light will start in DD? /ubbthreads/images/graemlins/confused.gif
Hmm... I see you mean non-rechargable CR123's. /ubbthreads/images/graemlins/banghead.gif
Status
