SonoraMike
looking for a recommendation on an LED headlamp setup that I'm trying to either put together or buy if it already exists.
This is for a night fishing setup, I'd like to find a LED headlamp setup that allows me to run:
1 - UV/blacklight: intensity should allow the light to project out about 10' or so in a somewhat wide arc. most fishing line will illuminate when the blacklight is on it, so the UV helps to track the line in the water and the fish are not able to see it.
2 - red: a somewhat bright red light that will keep my night vision intact but make it easy to tie knots, find gear, etc
3 - spotlight-like white light: i need to be able to clearly light up the shore/bank to see what is there, trees, rocks, etc. usually fish about 35' or so off the shore. this is optional, I can use a cheap lantern-like flashlight for this if it makes things too expesive/complicated. the red and UV are the real needs in this setup.
4 - switch: like a switch that I can flip to switch between UV/red/white
5 - rheostat: like to be able to control the power output and be able to crank up the power if needed for short bursts.
6 - power: open to any kind of battery setup, am assuming that I'd need to run some sort of remote battery pack and wire to the headlamp unit.
7 - weight: not really a consideration, but the lamp should be comfortable to wear without falling down onto my nose while I'm moving around.
8 - price: no idea, just in the idea stage so far
found this and thought it was an interesting setup (its not me in the pic...) where the red and uv could go in the bottom unit and then run a high intensity halogen or conventional white light in the top unit :
does something like this setup exist?? if not, can you make a suggestion on a parts list to put something like this together? want to make one and sell it to me?
any ideas/input very appreciated
thanks
mike
thanks
mike
