sotto
I just picked up one of the "New" Garrity LED Aluminum spotbeam lights from Walmart (very strong nice bright light). It has a single white Nichia LED. Anyway, I'm thinking of trying 2-CR2 lithium cells in the light instead of the 3 AAA's the light is supposed to run on. Will this likely be OK or will it likely burn out the white LED??
Also, could I directly substitute a green Nichia LED in this light without further modification? The LED's are polarized, is that correct? How do you ID the positive lead and will it burn out the bulb if you get the leads reversed?
Many thanks.
Many thanks.
