Considering a Mag85 (WA1185 in M*g3D body) or Mag66(WA1166 in M*g4D body) will draw 3.15amps or 1.97amps respectively at standard (no overdrive) rated voltages; these little AA NiMH's are not going to run that light for very long. I'd pass on all of the least expensive slooooooow chargers. I need a quick fix! Rayovac IC3 2000ma (truer to capacity 2000ma under loads of higher amps???) at 15min. per set of 4 charges would be my 1st choice now. But later in the year Eveready 2200ma 15min charge AA NiMH would be 1st choice. No Wally World in Singapore, but for those of us with access to Wally World; the Rayovac system costs $28 for the 4 cell charger +2 cells, and coupon for auto adapter. Get 2 of these for 30min charge time total. Then buy as many more of the 4cell blister packs at $13ea, as you need.
Same applies if you were going to do a couple of 3AAA-C adapters, and put into a Mag2C or 3C mod, get the Rayovac AAA 15min NiMH cells to use with this charger (the AAA's are good for up to 3amp discharges according to CPF member PeLu). Now all we need is low resistance 3AAA-C adapter????
