flashlight
Took apart my new VitalGear FB1-HA tailcap just to see how it's assembled & also as I plan to strip the HA off later. First removed the clip's hex screws with a Torx 'T-8x50 B5' tool. Then used a pair of long-nosed pliers, placed them in the slots in the metal retaining ring surrounding the central portion of the switch & turned in a counter-clockwise direction. The center switch & spring module can then be gently pulled out from where it's seated in the rubber boot. Finally the rubber boot can pressed out from behind. Also took close-up pics of the switch module itself.
