Re: Cold Heat Soldering update
i have to mention that i just got the 'cold heat' soldering iron as a gift, and.. i've been soldering for about 27 yrs (i'm 36).. and it's quite a little thing.. it is not going to replace any mainstay soldering tools, there are better ways to solder most things... however.. for certain applications it's perfect. Say you want to solder a wire to a switch or solder lug on a speaker, larger items like this.. it's awesome... took a while to figure out how to use it exactly...the commercials are misleading, making it look like it works as fast as spot-welding (which is basically what it is)... it uses the concept of 'spot welding' to use the item you are soldering to generate the heat.. the tip is actually a semiconductor (made of mostly carbon it would seem)... split in two, so power goes down on half, through the conductive item you want to heat, and back up the other half).. The 'trick' is that it takes a while.. soldering on to some fairly small terminals it took 12-13 seconds to heat it up nice n not to make a clean solder joint, but it worked perfectly, with no pre-heating like a normal iron, no plug like a soldering gun.. and when it's done, just like they show in the commercials.. it's instantly cool enough to touch with your finger.. technically.. it's probably 300-400 deg.. (it was just in liquid solder).. but is made of carbon with virtually zero specific heat so your cool finger cools it down so quickly you don't feel it. (just like how you burn your hand if you touch a pot in the oven, or the grates.. but not if you touch the same temperature aluminum foil).. In any event... for those types of jobs, not having to plug, not having a big bulky gun, not having the dangers of the heat of the iron.. it's genius.
I would definitely NOT attempt to use the coldheat in any semi-conductor situation.. it would probably work fine on axial lead devices like resistors or capacitors, but requires fairly big items to short out the split tip to make it work properly.
ps... to the original poster or forum moderator.. can you rename the title to something helpful like "Cold Heat Soldering Iron".. it was impossible to find this thread.
