I had some idle time on my hands so I thought I'd see if I could put an Aleph LE to good use. I usually EDC a modded KL4 on an E1e body, but after reading a posted suggestion by McGizmo, I gave it a shot.
I took my E1e head. I drilled it out just big enough to accommodate an SO17XA reflector. I then chased the threads with a 13/16-20 bottoming tap (mine's ground to go all the way to the bottom). I chased the threads all the way until the tap stopped.
I then assembled an LE with a BadBoy700 and topped it off with a TX1J luxeon.
All I can say is, "goodbye TW4."
The pics speak for themselves...
I was even able to use the stock lens. The body is one of jcciv's Vital Gear single cell bodies.
Well, I was going to EDC this thing and I just decided that it wasn't anywhere near finished. As I think I mentioned someplace, I removed the 17mm IMS reflector. That reflector is very good for applications that limit you to its use, but in this case, I turned down a McR27 and fit it into the head of the E1e. After having done this, it turned out that the E1e head was too long for the light engine to make electrical contact with the body, so I faced about 3/16" off of the back of the E1e head. While I was at it, I took off the hex part as well. I then stripped the anodizing off of the remaining parts of the head and the Vital Gear body; however, I took a shot at leaving the tailcap anodized to see how it looked.
Here are the results...
On the left is an E1e with the bezel ring removed. I just didn't have another, but I used a shim to raise it to the approximate height that it would have been had the bezel ring been installed. On the right is where I am now.
I think it's a good lookin' light, in the buff like that. I also think that the anodized tailcap makes for a nice contrast.
This pic shows some of the flaws in the finish of the light. The bezel ring was all beat up when I started and I didn't want to remove any more material.
And the beam shot. This was taken 20' from a white wall. This baby is now more that just a medium range light.
Thanks for looking.
Thanks for looking.
