L
led_replacement
Guest
I have recently modified a Brinkmann Pro-Max Mini 2 AA flashlight with a Tektite LT-1 Mini-Mag led replacement bulb.
To modify it you need to remove the Brinkmann reflector install the 2 pin LT-1 then install a Mini-Mag reflector in it's place. ( The Brinkmann reflector is too big for the LT-1 bulb ) After the modification the Brinkmann with the LT-1 led Nichia bulb focuses very well. The LT-1 is whiter and brighter than the Brinkmann bulb.
led_replacement
http://www.led-replacement.com/LT-1.html
led_replacement
