i recommend putting as many in series as possible.. but 15 in series being maybe as much as 40V or more might not be practical.... a driver that maintains constant current is a good plan.
this kind of light can be made with only resistors, but more info is needed.
identical LEDs is important for parallel design.. in-general.. resistor is needed for each branch.. i.e. you can have 3 branches of 5 LEDs or 5 branches of 3.. having groups in series will help even power distribution... a series resistance in each branch helps level each group, and each led in each branch will get the exact same current... it's a little tricky to have parallel and series in a long string, but it just means you have a set of parallel wires, but say 5 leds are wired in series with one resistor between the two wires, repeat as necessary.
-awr
