My pimped-out Nuwai Quantum-III
milkyspit
New Jersey
Hey everybody! /ubbthreads/images/graemlins/grin.gif Like so many fellow CPFers, I bought a Nuwai Quantum-III 1x123 light a while back, and while I thought it was a neat little light, I also found some things not to my liking... so naturally I began modding, heh heh... /ubbthreads/images/graemlins/wink.gif
Introducing... my pimped-out Nuwai Quantum-III! /ubbthreads/images/graemlins/grinser2.gif
Okay, well it looks pretty much the same as the UNMODDED Q-III. /ubbthreads/images/graemlins/frown.gif
In the interest of offering one example of what can be done with these things, here's a quick rundown of what I did, and why...
1. Replaced the stock LuxIII star with an SY0J binned star, which runs at lower voltage than stock and comes closer to a pure white color. (The original star had a distinctly blue tint.)
2. Replaced the stock boost circuit with a modified board pulled from a Dorcy 1AAA LED light, available for $5.94 at any WalMart. I've been using these boards quite a bit lately, both because of the low price and the easy availability. It does entail a little more labor to prep the board for use, though. Anyway, the board performs more-or-less like a MadMax, or perhaps MMLite and greatly increases the runtime of my Q-III over the stock board, plus fails MUCH more gracefully than the stock board did, with hours upon hours of lingering light that's bright enough to navigate around my house and find stuff in drawers. That's after 120 minutes of basically flat output, followed by 30 minutes of gradual dimming to the low output mode. Here's a runtime chart I did for my MilkMite mod, which uses the same circuit...
3. Removed the switch from inside the tailcap, and inserted an O-ring to recess the rubber boot just enough for the light to stand upright.
4. While the tailswitch was opened, I replaced the switch board itself with a dual brightness one from another Nuwai light, and replaced the resistance for the low beam with a 10 ohm resistor.
5. Added a stainless steel split ring from Berkeley Point, to facilitate easy lanyard carry. If you look closely at the photo, you'll notice something unusual about the split ring: one of the turns is missing around roughly half the circumference of the split ring. I snipped it off! This was because the stock split ring was a little too thick for the attachment point on the clip. After snipping some of the split ring off, it now moves more-or-less freely up and down at the attachment point, and doesn't seem to lose all that much strength... certainly not enough to cause it to fail under the small amount of weight of this particular flashlight!
The upshot of all this is a nice little light that can stand upright, attach to a lanyard, run for 2 hours at high brightness and STILL provide many hours of emergency light, and provide two levels of output: I measured the low output at 83 lux at one meter, and the high level output at 593 lux at one meter. That works well for me! /ubbthreads/images/graemlins/smile.gif
The point is, many mods are possible with this light. IMHO it's a great platform for modders! Yippee!
/ubbthreads/images/graemlins/party.gif
Mark2
Europe
Very nice! /ubbthreads/images/graemlins/smirk.gif Didn't know the Dorcy boards were that useful...
milkyspit
New Jersey
Cromag, sure you can get one fully modded! The price will depend on whether you're supplying the stock light, or I'm buying one on your behalf, then modding it. I generally charge $20-30 for the labor, plus parts cost and other expenses. PM me if interested! /ubbthreads/images/graemlins/grin.gif
milkyspit
New Jersey
Why thank you, Mr. Hotster! /ubbthreads/images/graemlins/grin.gif Your blessing pretty much officially endorses my mod. Now all I need is certification from the great MR Bulk to seal the deal! /ubbthreads/images/graemlins/wink.gif
Haesslich
Sweet. How much does the tint change, with the Y0? I'm thiking about a PM...
milkyspit
New Jersey
Neg, PM replied. /ubbthreads/images/graemlins/grin.gif
Pablo, the head unscrews at the point where the knurling stops, on the side closest to the clip... look closely and you'll see a seam there. It's Loktited shut, but you can break the seal with a couple pairs or pliers. However, make sure you protect the light itself with some rubber hose or something similar, so you don't end up with plier marks on the housing! /ubbthreads/images/graemlins/icon15.gif
Haesslich, the stock Q3 circuit and also the Dorcy circuit will both tend to shift the tint in the "warmer" direction, away from blue and toward green. Maybe the Dorcy circuit does so just a bit more, but it happens with both. Since Y0 is slightly on the blue side of white, this downshift moves the tint CLOSER to pure white. Hope that helps.
flashlight
Republic of Singapore
With the 2-stage switch is it still a clicky? Guessing that it's a click on High (or low) & click again for Low (or high). Pls. PM me a break down cost for a complete modded light. Thanks. /ubbthreads/images/graemlins/smile.gif
milkyspit
New Jersey
Flashlight, the replacement clicky has three states: off, low, high. Put another way, when the light is off, click for low, click again for high, and click a third time to turn off.
Sending PM in a moment... /ubbthreads/images/graemlins/grin.gif
flashlight
[ QUOTE ]
[/ QUOTE ]
Got it, thanks Scott. OK now don't forget to spend some time with the baby though. /ubbthreads/images/graemlins/wink.gif Up for a great mod. /ubbthreads/images/graemlins/thumbsup.gif
L
LED_experimenter
Guest
Hi Scott
I decided to take the plunge. My FIRST post!
Do you think a 5Watt Luxeon would go in without it burning up? Perhaps not sufficient room for dissipating the heat properly?
Also, can you describe any of the identifying numbers on the little driver chip inside the Nuwai 3Watt?
The one I have has a circuit board with a part number of C300-AL5W, is that the same number you have?
Thanks for your input.
Ed
milkyspit
New Jersey
Hey! Welcome, LED_experimenter! /ubbthreads/images/graemlins/grin.gif
I'm not sure a 5W Luxeon could be driven by the stock circuit. It might work underdriven, meaning it would be nowhere near the proper brightness, but probably that's about it. For the same reason, I don't think heat will be an issue.
I believe the primary chip on the board is a Zetex ZXSC300. It's a regulator, sort of, but in the configuration used runs more like it's in partial regulation, meaning it won't maintain constant brightness but will keep the light fairly bright for a while, before output drops dramatically when the battery is nearly depleted.
Yes, that's the same code as I've got on the stock circuit board. I think the C300 part refers to the ZXSC300 regulator, and suspect that the AL5W part means this board was originally designed to drive a 5W emitter off TWO 123 cells. That said, it's just a theory, as I haven't tried it yet. But if you're prone to experimenting, try it! /ubbthreads/images/graemlins/naughty.gif Put a replacement circuit in the QIII, such as the Dorcy circuit I used, and perhaps try running the C300-AL5W board to drive a 5W emitter (properly heatsinked of course) with 2x123 cells.
Good luck with your pimpin'! /ubbthreads/images/graemlins/wink.gif
milkyspit
New Jersey
Cromag, I replied to your PM last week as well. Not sure why you didn't notice it... or maybe for some reason you didn't receive it at all?
/ubbthreads/images/graemlins/thinking.gif
I'll cut-n-paste that reply plus add a bit of new info, and send you another PM in the next 10 minutes. Watch for it! /ubbthreads/images/graemlins/smile.gif
L
LED_experimenter
Guest
Hi Scott (or, is it Milkyspit?)
I tried that quick change, but it didn't put out much more light or current. I believe I need to change the smd resistor value. The resistor number is R050. I am not sure if that is 0.50 ohms or .050 ohms? I never worked with such small values before. As near as I can figure, I should reduce that resistor to 1/2 the present value. On the boards you are removing, is there a different number on the smd resistor?
Does any of that make sense to you? Do you have a recommendation for the smd resistor? I know you prefer the board from the Dorcy 1AAA, but I have a frugal streak in me (I hate to waste things), so I am trying to make the original circuit board work.
Do you think I am trying too hard to preform a miracle, by saving that board?
I know, I ask a lot of questions! (HEY, where is the spell checker /ubbthreads/images/graemlins/ooo.gif)
OK, that's it for now. I don't want to over extend my welcome, since I am only a 'newbie' here!
Thanks
Ed
milkyspit
New Jersey
LED_experimenter, you can call me Milkyspit, Milky, or Scott... they're all fine by me! /ubbthreads/images/graemlins/smile.gif
If memory serves, my resistor was either R050 or R020. I don't think changing the value will help you much, because on this board the resistor doesn't set the output current by itself, it only sets the PEAK output current. In other words, if everything went perfectly and your battery were able to deliver all the power in the world, your emitter would run at 950mA using that stock resistor. (I had calculated the value based on the Zetex datasheet for their chip.) However, in any less than ideal situation, which is definitely the case with a single 123 cell being asked to deliver massive amounts of juice on a continuous basis, the chip will begin sending PULSES to the emitter. Each pulse may well be 950mA, but because it's not continuous output, it has the effect of making the LED look dimmer to the eye. For my Q3, the output was comparable to other lights I've got running in the 350mA-500mA range. It seems that the battery itself is the limiting factor in this light, so reducing the resistor probably won't do a whole lot for you. /ubbthreads/images/graemlins/frown.gif
Regarding the Dorcy 1AAA, it's $5.94 at WalMart, man! Think of the amount of time you'll spend tinkering with the stock circuit, probably fruitlessly, when for less than $6 you could just pop in a different circuit that you know is going to work. /ubbthreads/images/graemlins/wink.gif
BTW, I didn't waste those Q3 boards, just haven't told you what I did with them yet, heh heh. /ubbthreads/images/graemlins/naughty.gif
absoLite
Scott,
very interesting light you did /ubbthreads/images/graemlins/happy14.gif
I have some questions about it:
Does it have more throw than the original QIII, or does it have more sidespill, or perhaps both ? /ubbthreads/images/graemlins/grin.gif
Would the 2-stage switch also be possible with an original QIII, and if yes, would you sell one and for what price ?
