Re: Lionheart extend
[ QUOTE ]
LightChucker said:
glockboy, that looks great!
Could you do me a favor and ask your friend if he would make one for me?
Oh, one other question - is there any risk that the increase in power would damage the LH?
Thanks,
Chuck
[/ QUOTE ]
The Li-ion 18650 cell has the same voltage as the Pila 150A/S or Pila 168A/S, so there is absolutely no danger of damage.. /ubbthreads/images/graemlins/grin.gif
The great thing is that the LH circuit already has a built-in low voltage regulator that will cut off the battery when voltage drops below 2.75v (I think), so you really don't need to use the Pilas at all and can use the unprotected Li-ion cells. The great thing about unprotected Li-ion 18650 cells is that they have up to 2400mah versus 1800mah from the Pila 168A, meaning you'll get an additional 25% of runtime.. /ubbthreads/images/graemlins/smile.gif
glockboy, I'll also be in for one if you're doing a run..
