Enigmahack
- Joined
- Nov 12, 2004
- Messages
- 139
So here's what I did - I took it apart, moved the little turny thing until it was really bright and then it turned off, so I turned it back a little. *that was fine*
But then I noticed that it got REALLY REALLY bright when I touched the metal peice that I was using to turn the pot to the outer case.
So I ran a wire from the little pot to the casing. *I set it up to make sure it doens't move around and short something out* and also moved the little diode *loosened it and then "aligned" it and made a little mark to make sure it was aligned properly* and when I turned it on... WOW.
I can't leave it on for more than 30 seconds, it starts to get warm, but it's VERY bright. Bright enough that when I shine it at a white wall less than 5 feet away, it is very hard for me to look at it without at least looking away or something.
I wish I had a little meter to sort of scale HOW much output it is, but I don't have a multimeter to be able to tell what the Draw is from the diode or whatever you'd measure... but I saw those little things you shoot your laser into and it tells you what the MW rating is and I was thinking that'd be neat to get.
Anyway, I guess based on pics that I've seen that it's probably around 20-30 mw, (and I did NOT touch the IRfilter - that was staying on) but I'm interested if there's any real low-tech ways basically of telling or if there's any methods anyone knows of that I'd be able to check out?
Anyway - Just wanted to say "I'm a hypocrite" for saying that I wouldn't mod it and then I do a two-stage mod on it lol. And to see if there are maybe some comparison shots that I'd be able to say "yeah, my laser looks like that one" for output to get an idea of what I'm playing with here.
Anyway, that's my little story /ubbthreads/images/graemlins/smile.gif
