Zigzago
I'm using a Madmax Lite in a 1AA mini-minimag. I like this setup alot, but sometimes when I twist the light on it is dim, maybe one third its normal brightness. Slapping the light will restore it to brightness. Moving the LED from side to side in candle mode will cause it to switch between dim and bright mode.
The sandwich works fine in a 2AA minimag. After swapping all the components it seems to be related to the battery tube of the 1AA light. I've tried cleaning the tube and the upper surface of the sandwich with no effect.
Has anyone else seen this and/or know how to fix it?
Thanks
Thanks
