Re: Difference with nimh batts 2100 -2500 and char
In general, if you have a low current demand application, any capacity is fine. In fact, the higher the better for more capacity. However, if you use lights with higher draws, then the hi-cap cells lose their advantage. The best thing is to go with the general guidelines and understand that YMMV. For example, I use Energizer 2100s in a 3.2A application and they perform very well compared to the premium MAHA Powerex 2000s.
Sway,
Did you every check the individual cells to see if you had a dud in the string?
Wilkey
