Olight - R50
Results 1 to 23 of 23
Thread: Where to buy Silicone Grease? (a small tube preferred)
    Flashaholic* Spudman's Avatar
    Jun 2002
    Kentucky
    Default Re: Where to buy Silicone Grease? (a small tube preferred)
    I found some at a watch repair site. I can't seem to find the link. It was about a two ounce jar. I also found some at diver's supply stores, but the cost was a little higher.
    G.
    Jul 2002
    seattle, wa
    Does it say "silicone grease" or maybe under a slightly difference name?
    Jun 2002
    Kentucky
    Mine said silicone grease. I did a google search with that name to find it. On the box it said "silicone grease for watch repair" Sorry I lost the link.
    G
    Aug 2000
    Silicon Valley, CA
    I ordered online from a scuba shop, they all sell it. Don't know if it's "dielectric" though.
    http://www.candlepowerforums.com/cgi...c;f=1;t=002313
    It's not a "small" tube but it is a true Silicone Grease.
    Eric
    Mar 2002
    LA,CA
    Teflon gel lube at radioshack works well on the o-rings on flashlights, part #64-2326
    http://www.radioshack.com/product.as...5Fid=64%2D2326
    Aug 2001
    VA
    The Brinkmann website sells O-ring Lube. It's kind of pricy but the shipping is free.
    http://www.thebrinkmanncorp.com/acb/...ectGroup_ID=27
    PS the flipoff lenscap with colored lens is great as well, to protect your lenses. Fits mags, E2e, ARC LS, etc.
    Flashaholic* Slick's Avatar
    Apr 2002
    Nor Cal
    <font size="2" face="Verdana, Arial">I got mine at NAPA and it's called "dielectric silicone grease". It's clear, thick, and slippery. It was next to the sparkplug wires on thier display.
    Jan 2002
    Kansas City, MO
    Can I use dielectric grease for o-rings?
    Jul 2002
    seattle, wa
    Default Where to buy Silicone Grease? (a small tube preferred)
    Any retail store carries them?
    Administrator
    May 2002
    Missouri, U.S.A.
    I have seen small tubes in the automotive section at WalMart. (mini gease gun tubes)
    Sep 2001
    NYS
    Ace Hardware...plumbing section is where I got mine. Usually automotive departments will only carry Lithium grease. NOT the same.
    Flashaholic* sunspot's Avatar
    Aug 2001
    Graham, NC
    Auto part stores carry dielectric silicone grease. I got a sample pack for $.25 at AutoZone.
    Oct 2001
    AZ, USA
    Automotive parts store ... ask for disk brake lubricant. Shouldn't cost more than a dollar.
    Apr 2002
    Nor Cal
    <font size="2" face="Verdana, Arial">That's what I'm using it for...
    It also works great for keeping sparkplug wire boots from adhering to the sparkplugs on my shovelhead. [img]images/icons/cool.gif[/img]
    Be careful with products that claim to be Teflon or Silicone; they may still contain petrochemicals which are devastating to some O rings, especially those made with butyl rubber. If in doubt check with the manufacturer to see if the rings are petro safe.
    Here is an excellent, non petroleum based product popular with CPF'ers a while back. They used to send free samples; I still use mine.
    SUPER LUBE
    Brightnorm
    Flashaholic* Quickbeam's Avatar
    Jun 2001
    FlashlightReviews.com
    I use dielectric silicone grease on all my lights/o-rings (and sparkplug wires). No problems at all.
    Aug 2000
    Silicon Valley, CA
    Question: how would I know if my silicone lube isn't dielectric? Since it eventually gets on the threads, I assume that a non-dielectric lube would disrupt the circuit, and I'd lose some light output. Since that hasn't happened, I'm assuming I'm using a dielectric grease. And I'm assuming here that "dielectric" means "conducts electricity".
    Joe
    Jun 2001
    Dielectric grease does not conduct electricity.
    Never had a problem with it. If the contact surfaces are held together with enough pressure the grease pretty much moves out of the way and allows metal on metal contact. I coat the batteries in my photon 2's with it and have never had a poor contact problem (and also have never had a problem with water/corrosion.)
    Aug 2001
    Graham, NC
    <font size="2" face="Verdana, Arial">Yes. But. Most grease will not stop conductivity. There is still lots of metel contact at the threads. I read a rather long thread about this issue that I won't repeat here but the end result is not to worry.
    Jun 2001
    Ignore this post... Helps if I READ before I post [img]images/icons/tongue.gif[/img]
    Flashaholic* ElektroLumens's Avatar
    Jan 2001
    Cottage Grove, Oregon, USA
    I get mine from Digikey, a 5 oz. tube. It is dialectric silicon grease. The part number is 345-1608ND, and it is $21.63. A 5oz. tube lasts a very long time.
    Wayne J.
    www.elektrolumens.com
    Wayne J.
    <font size="2" face="Verdana, Arial">Wayne,
    Is this a high viscosity grease or a thinner one? I prefer one-hand operation for most of my twist-on lights and the type of grease makes a big difference.
    Brightnorm
