*Flashaholic*
Re: Optolight $1.00 4xAA mini-review + photo
Are you sure power source isn't (4)AAs instead of 3?
I'm mostly interested in the battery carriage. With alkies, does it fit into a D light? Will two fit into a 2D Maggie? 3 into a 3D Maggie and so on.... The batts look like a tight fit to begin with. Will the carriages with NiMH batts fit into Maggies?
73
dim
*Flashaholic*
It looks very similar to the dorcy neon colored somethingbright light that biglots has for 2.99 with batteries.
The cartridge might fit into D light bodies if trimmed a bit around the edges.
4xAA : D is a somewhat dicey proposition. When it does work, there is usully ZERO margin.
I hear that newer highcap NiMH cells are somewhat larger than alkaline AAs, so four often don't fit within a D footprint.
Good candidate for an EverLED replacement bulb...isn't it?
Add one and u have a $40 1.2W Luxeon flashlight
$1 ??? Wow, I want one! [img]/ubbthreads/images/graemlins/grin.gif[/img]
*Flashaholic*
Run one dummy AA in the holder and DD a Luxeon 3 up top (with a big hunk of aluminum heatsink ground to fit, of course...).
Hey Charlie, that's what I got in my "Mini" SN2 clone [img]/ubbthreads/images/graemlins/grin.gif[/img]
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
Forum Rules
