BuddTX
(The review catagory was there, but then dissapeared again, so I will post this here!)
Some days, there are no lights in the mail. Some days, I get 4 (LIKE YESTERDAY!) (Danger Will Robinson, Flashlight overload!)
My Inova replacement was delivered, as well as a very small package from Inretech, containing a Super6, a 2AA drop in LS for a mini mag, and a RED drop in replacement for my mini-mag. (The two drop in's were nice, I will review them later)
I first became interested in this light, when Craig posted his review on the LED Museum (Thanks Craig for another GREAT review!):
http://ledmuseum.home.att.net/super6.htm
Here is Inretech's web site:
http://www.inretech.com/
I like flashlights that fit in the palm of my hand, or in my pocket. "Big lights" don't inpress me as they once did. Show me light output, not a big huge pipe.
Ever since Flood Allison, last spring, when the Hospital that I work at had a horrible flood, and we were without power totally for three days, and did not get power restored totally for 13 days, and I was dissapointed with my "big lights" that I thought were as bright as one could buy.
Well when I first saw the Inretech Super6 drop in module for my Mag 3-D, I was interested, but questioned whether I would want to start using my, beautiful, but clunky and big, Mag 3D again.
Well, after installing the Super6 in my Mag, I have one answer:
YES, YEA BABY, THIS IS SOOOO COOL, WHAT A USEFUL LIGHT, WOW! (Do football touchdown pass dance now!!!)
Let me jump right to the light output:
Don't think of this as a "FLASHLIGHT", think of this light as a handheld "DIRECTIONAL LANTERN". Absolutely NO BEAM. There is no hot spot, no center, no weak outer ring, just PURE, EVEN, VERY WHITE, LIGHT!
You can just hold the light at your waist, or wherever, and see EVERYTHING in front of you. With your head facing the same direction as the light, your entire field of vision is lit up. No need to spotlight anything, no need to move the light, or re-position it. I moved my eyes as far up, down, left and right, without moving my head, in a totally dark room, and there was no darkness to be found!
A totally unique and welcome different type of light.
For a disaster, or a group working in the darkness, it's almost like a battery operated drop light, (but whiter!)
Well, I mentioned color, and the color is that bright, very white, almost flourescent color light, that you expect from an LED, not a yellow as a traditional incandecent drop light would give. And don't worry about that "puke green" color from the Luxeon Star's. No hint of green at all.
I e-mailed Mike Boyd of Inretech, and was a little concerned about the installation. "I am not too good at soldering", I told him. I was a little concerned about the skill level needed to install this behemoth 6 LS replacement. He replied, "it will take you longer to open up the box, than it will to install it". He was right. Even with no instructions, it took me under a minute to take apart my 3D mag, and install this drop in replacement.
I am not even going to go through the effort to describe how to install it. It is about as easy as changing the bulb on a MAG, but you just don't have to replace the locking collar. (BTY, there is NO SOLDERING!)
Now I put this light, turned on, on the back of my pickup truck, along with my Streamlight 4AA, 7LED light, and walked across my Cul-de-sack, to see how it looked "from afar". From about 200 feet away, the Streamlight looked much brighter, and after thinking about it for a second, I understood why. The 7 Nichia LED's on the Streamlight are "Directional", whereas the 6 Luxeon Stars on the Inretech are truely non-directional. Light gets dispursed very evenly in all directions.
There are so many times where I wanted a portable flashlight to work like this.
Now the only thing, is to get some kind of anti-roll device for the mag, and possibly a way to hang it from a high point above, but I am sure that there must be lots of add ons for the best selling flashlight to take care of those features.
Inretech does not seem to be a hobbiest company. They appear to me to be in business to make lights commercially, so availability should not be a problem. I like how Craig reviews Hobbiest "mod's" different from commercially available lights.
The price is 125.000 for just the drop in, or 140.00 for a complete light.
The 6 black boxed "resistors" (I think that is what they are) are much less obtrousive than the above picture posted on Craig's site. That must be a prototype. Mine looks like they are flush mounted with the green circuit board, and look much more professionaly finished.
I am pretty sure that Mike told me that this unit is direct drive, but I will confirm that. (I might have gotten it confused with the LS mini-mag drop in).
My only complaint, is that, when looking at the circuit board, with the light off, there seems to be an empty space, right in the center of the board, just silently screaming for just one more LED . . .
EDIT - Mike just e-mailed me, and, while I was being (semi) humorous about the 7th LED in the center, he said that he did consider putting a 7th LS LED in the unit, but he said that "it didn't route as well".
After all, if someone came out with a 137 LS LED emmiter, SOMEBODY would want a 140 LED version! (AND WHY NOT!)
