brightnorm
- Joined
- Oct 13, 2001
- Messages
- 7,160
APPEARANCE: Identical to original except in length
LENGTH/ WEIGHT/ ERGONOMICS:
Reactor: L - 6" Wgt (with batteries) 3.5 oz
Reactor III: L - 8" Wgt (with batteries) 5.4 oz
Reactor III is noticeably heavier than original but well balanced when held in middle of barrel. Longer barrel permits more secure hold on light.
SWITCH: Combination of original (infinite turn, vague indents for on/off),
and "improved" original (center on, with right and left off/stop).
Reactor III has infinite turn with clearly defined positions for on/off with a clearly tactile detent for "full off".
BEAM CHARACTERISTICS:
SHAPE: Well centered and smooth with central hotspot approx 12-18" diameter at 7 feet blending smoothly into very bright corona of approx 3-4 feet in diameter. Hotspot and corona are so smoothly blended that there is almost no delineation between them. Modest ambient light spill makes for relatively narrow beam.
BRIGHTNESS: Slightly more than twice as bright as original Reactor. By way of comparison, my LGI is easily more than twice as bright as the Reactor III. Please note that because of Luxeon's inconsistency these observations apply only to these specific lights.
COLOR: A subtle aqua. Reminiscent of ARC AAA LE beam color. In no way offensive.
RUNTIME: To be determined. Started simultaneous run with original Reactor. As of this post one hour has elapsed.
RELIABILITY: I received two Reactor III's from Shomertec. The second one quit after 20 minutes, restarted and functioned erratically until it finally died after one hour and could not be restarted with new batteries.
Both Reactor III's were loaded with fresh RAY-O-VAC Maximums. The original Reactor was loaded with fresh Energizer lithiums.
TENTATIVE CONCLUSIONS: If bright runtime is extended, and if the problem with the second Reactor III proves to be very rare, then this would be a practical addition to a collection and the brightest low priced commercially produced luxeon light to date. I am not currently able to test the light outdoors, and I have some questions about the suitability of the relatively narrow beam for walking /hiking. I'm sure others will start reporting in soon and will fill in these gaps.
Brightnorm
Brightnorm
