Hi, I'm a long time reader and first time poster!
K5Guy, I agree that you got a good deal. I bought my 6R back in '97 and still have it today. I've added a few things to it since then, but it is still serving quite well. It cost me about $96 with tax. I've spent more on it since then!
As has already been posted, SureFire used to offer the 6R which was basically a 6P already fitted with the Recharge Kit. Back then, this consisted of an 50 Lumen R60 lamp assembly, B65 NiCd battery, charger, and A14 mid-body adapter. The R60 is no longer made, but the P60 can be used with the B65 battery. The P60 will give more lumens, albeit with a slightly reduced runtime.
What this means is that you are, in essence, getting both a 6P and a 6R at the same time! (or in today's SureFire terms, you're getting a 6P with the KR2 Kit) You can pull the mid-body adapter out and run the light with 2 x 123 lithium cells as a 6P, or use the adapter with the rechargeable B65 battery. For that matter, you can get an A19 adapter and a P90 lamp, and you will have a 9P...you can configure the flashlight in all the ways that you can a 6P!
When you get the light, check the charger. If it is the old style (mine was the CN100 model), then it is a run-the-battery-all-the-way down style, which requires you to charge for 12 hours, I think, then take the battery off the charger or risk damaging the battery. If this is the case, you would be best served by buying the newer charger (I now have a CN200 series), which charges the battery in about an hour, allows you to charge the battery before you run it all the way down, doesn't damage the battery if you leave it in the charger too long, and tells you when the battery is charged (a red LED is lit while the battery is charging, then goes off and a green LED lights when the battery has been charged).
