Snoopy
- Joined
- Oct 5, 2004
- Messages
- 41
After modifying the reflector head and lamp holder for powerful halogen lamps, the third component to take care of is the switch unit. Heat is not that much of an issue in this case but the current rating of ~1A definitely needs some upgrading. What we are looking for is a permanent load of approximately 10A to cover every bulb up to 100W@12V and a soft-start function to increase the average life of our bulb and to avoid problems with powering up high performance types (30+lm/W). Furthermore, we want to maintain the waterproof (well, more or less) design and achieve a professional appearance.
The basic idea, Figure 1, is rather simple: To avoid overloading the electrical contacts the bulb current is switched by a MOSFET between battery pack and bulb. The MOSFET works like a voltage-controlled resistor. When a voltage is applied between Gate (G) and Source (S), the Gate-to-Drain resistance is low (lamp on), for zero control voltage it is high (lamp off). Now, the original switch is used only to control the MOSFET.
Figure 1: Electronic Circuit
The peripheral components R1, R2 and C1 provide the soft-start function: When S1 is closed the Gate voltage gradually increases and as a result the gate-to-drain current rises slowly, giving the filament some time to heat up.
The main advantage over other solutions, i.e. Willie Hunt's LRVs, is the low cost. However, in our case you don't get a voltage regulation. The electronics doesn't require much space and is easily installed on the original switch assembly (Figure 2) or on the battery pack (Figure 3). For the higher current bulbs (35W/6V in Figure 2, 100W/12V in Figure 3) I'm using two MOSFETs in parallel to improve power dissipation. Since in both cases we are using the original switch, no machining of the body is necessary and the modification remains invisible.
Figure 2: Electronics installed on Original Switch Assembly
Figure 3: Electronics installed on Battery Pack
In Figure 3 you can see how the electrical contacts from the lamp holder and the switch are soldered to the PCB.
That's all for now, folks.
Regards,
Snoopy
Regards,
Snoopy
