Re: Anyone with a comparison pick of the Aleph1 an
If you want a smallish light that will serve as a sort of "jack of all trades," then an Aleph I on a 2X123 body with a Lux III being driven by a DownBoy converter should work nicely for you. It will give a good flood that is accompanied by VERY good throw. It will run on 2X123 and if you wanted, you could also run it on a Pila 168S. You won't get regulation on the Pila, but you will get over 700mA to the luxeon and the output will be pretty flat, due to the discharge characteristics of li-ion cells.
You could opt for a Wiz2 converter, which would give you regulation on either 2X123 or a Li-ion. The advantage to the DownBoy is that you could run it on up to 4X123 for some really long runtimes, if you could find a body that long.
