Foxfury Scout
Results 1 to 13 of 13
Thread: Green laser line generator
    Unenlightened
    Jul 2004
    South Dakota
    Default Green laser line generator
    I paint the lines on parking lots and have been toying with cheap red laser pointers and line generators, now I am on the search for a green laser line generator. Parts would be fine (diode), any help or suggestions would be greatly appreciated. Thanks to all in advance, Ross.
    *Retired* The_LED_Museum's Avatar
    Aug 2000
    Federal Way WA. USA
    Default Re: Green laser line generator
    All you would need to do is affix a cylindrical lens to the front of an existing green laser - pointer or other style.
    Of course you still have problems when an insurmountable obstacle stands in the way.
    Another case of "it's not my job", I guess.
    [img]/ubbthreads/images/graemlins/hahaha.gif[/img]
    Unenlightened
    Jul 2004
    South Dakota
    Where would you suggest I find a cylindrical lens?
    Flashaholic* Raccoon's Avatar
    Dec 2004
    New Mexico Tech, Socorro NM
    I'm also interested. It would be neat if such a lens could be mounted on a cap that fit the leadlight.
    Aug 2000
    Federal Way WA. USA
    [ QUOTE ]
    [/ QUOTE ]
    I found one a long time ago in some type of computer peripheral (a printer, more likely than not) that used a long bar filled with yellow-green LEDs. The lens was a long glass rod, which was easily broken into small segments. Those segments, when placed in front of a laser, caused it to generate a line.
    I'd imagine that you could acquire a glass laboratory stirring rod, smash it, and pick a piece that's approximately 0.25" to 0.35" long, and there, there's your cylindrical laser line generating lens. [img]/ubbthreads/images/graemlins/smile.gif[/img]
    Unenlightened
    Jul 2004
    South Dakota
    Are there line generating diodes?
    Oct 2004
    Bonner Springs, KS
    Here is an optic...Merideth Instruments
    Here is a line generator I picked up to play with, basically a spinning mirror that will throw a line over 120 degrees wide, I mounted this to a board along with a green pointer for the line effect, works real good... Merideth Inst Parts
    Unenlightened
    Jul 2004
    South Dakota
    I think the best choice for me is to buy a pointer and add a line generating optic. Will a higher power laser pointer (10-20,30mW) fry an Acrylic lens?
    Dec 2004
    No. It will barely warm a black garbage bag let alone a clear one.
    Leadlight is producing a green laser line generator. I have a sample - it works pretty well. I think the product will be available this summer sometime.
    Dec 2004
    Does Bigha work pretty closely with leadlight? I wish they'd make a rheostat dial butt cap to adjust brightness of their light. Bigha should too for their Jasper.
    I have a professor who complains about the brightness of a 3mW-5mW leadlight. The green is just too bright and dazzling for the class in a dimly lit classroom. A faint green dot has its place but can only be achieved with a dimmer of some sort.
    Sorry, I know this has nothing to do with line generators. But leadlight accessories would be really nice.
    PS. Nice to see you posting again.
