WildRice
Everything finally came together, although I wanted a 2C m@g to host this, 1.I couldent find one, 2. probably too $$$. I opt'ed for a garrity disposable jobbie.
I epoxied the reflector to the 'star' base of the prolight RGB, and epoxied the clear protective flashlight cover to the top of the reflector. I took a CPU heatsing and cut it in half and thermally epoxied it to the assembly.
I then gutted the garrity and cut out a few bits to make everything fit.
First to install was the optical assembly.
I then removed the guts from the 'sauce' wand. here you can see the 'sauce' controller board and the transistor switching board.
And finally, everything installed. I modified the original switch spring by gluing a pbtn under the contact spring. At this time I devided to keep the 1.5v driver circuitry, so the LI AA is hardwired to the controller and the Li-ion is hardwired also.
Sliding the switch up cycles through the light sequences, and it has an aoto off after about 4mins.
MPG clip ~1.7Meg
Above is a clip about 4 feet away from a white door. there is a 'hole' in the red light, but the mixing is pretty good.
Jeff
MPG clip ~1.7Meg
Jeff
