Thanks for the info - I'll be sure to check out the site to double check. I re-read my post though and now I think I made a mistake: what I want to do is use 6 Luxeon I stars each driven at 300mA. I know the Fatman has a 12V limit, and I would likely be using 2 18650 2400mAh LiIon cells to power it. If each Lux has a Vf of roughly 3.2 volts, that is 9.6 volts at 300mA that the fatman has to be able to provide per set - if wired parallel with the other set then - if I'm understanding everything right - the Fatman would need to provide 9.6 volts still but at 600mA? For the W=V*I formula that would only be 5.76 watts of power - so to rephrase (though I'm sure you are still probably right anyway), I want to know if the Fatman can power 9.6 volts @ 600mA from a 7.2-8.4 2400mAh source (assuming I added everything right). Thanks again,
Dan
