pastanley
Well, after reading all the different threads on disassembling the Q3 head, I tried it so I could replace the plastic lens. I got the bezel off with a small propane torch (I was careful not to overheat). Once I did that, I was able to get the reflector out and then the plastic lens out. I must say the stock lens was in terrible shape for only having the Q3 for a month or so. It was totally scratched up and it was actually kind of blurry looking through it.
I replaced it with a 22mm domed mineral glass watch crystal. What a perfect fit. I spent an extra couple of dollars and got a nice flat bottom, domed top mineral crystal that is pretty thick in the middle. I don't know the exact thickness in millimeters, but it is at least 2.5 mm in the middle tapering down to maybe less than 1 mm around the edges. (Sort of like the lens on the new K1 bezel, but not nearly as domed or as thick.) Once it is in the light, you can't really see the dome to it unless you are really looking for it. Total cost was $7.50 plus tax. You can get a regular domed crystal (no flat bottom) for $3.50 and a pack of 3 regular flat mineral crystals for $3.50 too. Since I was upgrading, I went for the nicest I could find. A sapphire crystal would work too, but that increases the price to over $30+. I don't want a lens that cost more than my light.
Anyway, I was very pleased with the way it turned out. I would post a picture or two, but like I said, you can not really see how nice it fits or looks in a picture. It definitely makes a difference though. It is so clear. I am now almost blind from checking it out so many times since I installed it yesterday. It appears that it did not really do anything noticable to the beam shape. It may have a little tighter beam now, but I don't have another Q3 to compare it to.
If anyone is interested, you can get almost any size and type of watch crystal from:
http://www.ofrei.com/page_157.html
They have a minimum $15.00 order requirement, but I actually work down the street from them so I was able to get around that.
OK, that is all. I just thought I would share my first modding experience with everyone.
