sunbeam,
The sandwiche shoppe carries them, and jsburly's has them. I'm using jsburly's cells and like them.
Just keep in mind that there is a fine line when driving a lux V with two 123 size cells. If running 2X123, you'll need to use a boost converter. When running 2XR123, you'll need a buck converter.
My point is this. I'd go with a 3X123 body, with the buck converter, if I could. This way, you could use either the R123s or 123s in a pinch. If you go with the two cell body, you're going to limit yourself to the use of the li-ion cells.
