Foxfury Scout
Results 1 to 6 of 6
Thread: NiMH in NiCad charger?
    Jul 2001
    USA
    Default NiMH in NiCad charger?
    What happens if you recharge NiMH batteries in a NiCad charger? What exactly is the difference in the way they need to be recharged? The first set of NiMH batteries I got, from Radio Shack at least 1 1/2 years ago, have been charged only in a NiCad charger. They seem to work fine, giving around 3 times the life of a standard AA NiCad. I purchased an Eveready charger, that has a switch for NiCad/NiMH. Now that I'm getting more and more of the NiMH AA batteries, (Rayovac 1600 mAH AA's from Walmart; $11/4PK +tax)I'll need to get 1 or 2 more chargers. (Probably for AAA/AA only) But I wonder what I may have done to the set of NiMH I've been rechargeing in the NiCad charger. [img]images/icons/blush.gif[/img] [img]images/icons/frown.gif[/img]
    Dec 2000
    San Gabriel Valley
    Default Re: NiMH in NiCad charger?
    I don't see anything wrong with what you've been doing, but if I were you I would get a pulse type unit.
    That way, you won't have to make a Career out of charging batteries [img]images/icons/tongue.gif[/img] and it's supposed to be a lot easier on 'em.
    *editorial-I used to hate rechargeables bcos you had to "babysit" them, and wait hours and hours and More hours.... [img]images/icons/frown.gif[/img]
    -I just now put in an exhausted NimH AA-1600mAh, but I will have that battery Back in full service in 90min! [img]images/icons/smile.gif[/img]
    I found that on one type of charger, the NiMH/NiCd switch was just a 'feel good' switch. The idea is that NiCds will accept a higher charging rate compared to NiMHs. The thing was that the maximum charging rate was a fair amount LOWER than the maximum allowable charge rate for the NiMH batteries.
    Thus, the switch did nothing at all. I have been charging NiMHs on NiCd chargers for years without problems. I do, however, tend to use a lower charge rate (140 mA) unless I am in a hurry, as I feel that the heat generated by the rapid charger (240 mA) is detrimental to the cells.
    Walt
    Dec 2000
    San Gabriel Valley
    <BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Walt Welch:
    Walt
    <HR></BLOCKQUOTE>
    Not necessarily an argument with that, but on the newer rapid-pulse units I've been using, the cells are always only mildly warm when they're through charging.
    (The included manuals mentioned thermal detection circuits, amoung several other protective features...
    -That's probably why these type chargers are noticeably more costly.
    BTW-I've been able to save about 20 batteries, using this device,
    -that I would have had to throw away otherwise.
    Aug 2001
    VA
    I was wondering if it was a good idea to run a fan over the charger while charging batteris? It does keep the cells significantly cooler. Or at least the outside temp, not sure about the internal temperature.
    Dec 2000
    San Gabriel Valley
    <BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by cave dave:
    I was wondering if it was a good idea to run a fan over the charger while charging batteris? It does keep the cells significantly cooler. Or at least the outside temp, not sure about the internal temperature.<HR></BLOCKQUOTE>
    Sure wouldn't hurt matters.-As you know, too much heat sure doesn't help rechargeables...
    -If those batts. are hot to the touch-(I occasionally check 'em on my inner forearm), a small fan sounds like a good idea.
