Results 1 to 6 of 6
Thread: Nuwai headlamps: Rechargeables?
    Flashaholic* Phaserburn's Avatar
    Mar 2003
    Connecticut, USA
    Default Nuwai headlamps: Rechargeables?
    Nuwai has 2 versions of a popular headlamp, 1W and 3W. I believe the 1W is model 712L. Can either of these regulated headlamps use R123s? Anyone have experience?
    Default Re: Nuwai headlamps: Rechargeables?
    Nuwai has many popular headlamps. Please see here:
    http://www.amondotech.com/index.asp?...p;Category=503
    If you are planning to use rechargeable batteries, you may consider to choose headlights taking AA or AAA batteries. Then, use NIMH rechargeable ones.
    Regards,
    Wayne
    Are there reviews of these headlamps. How do they compare to the corona?
    Apr 2005
    SF Bay Area, CA
    [ QUOTE ]
    Regards,
    Wayne
    [/ QUOTE ]
    Does that mean the models using CR123's cannot take rechargeables R123's?
    I am not sure the models take CR123A will or will not take RCR123A. The voltage for these two batteries are slightly different.
    The Duet LED flashlight is very popular:
    http://www.amondotech.com/index.asp?...amp;ProdID=867
    It takes AA batteries instead of CR123A.
    Here is the review:
    Regards,
    Wayne
    Flashaholic* NoFair's Avatar
    Dec 2004
    Norway
    I've got this duet light, almost the same as I've got the 4AA rechargeable version. Pretty satisfied, got it cheap. And you can replace the stock battery-pack with one with better cells. The ones that come with the light are 1200mAh.
    Some beam issues, but of little practical importance. Battery indicator is handy and the nichas will work for a while after the Luxeon shuts down on low batteries.
    I think a Favourlight version of this non-recharable light is reviewed on flashlightreviews.com. Same light different name.
    Sverre
