andyz
Well not quite but what if I add a red push button to it /ubbthreads/images/graemlins/grin.gif
Well some of you guys have seen my Surefire mod so seeing as I end up with a bunch of spare Leadlight Cases I figured why waste them, so I built this unit over a shortened Leadlight Case -
<font color="red"> Large Heat Sink Collar allows for a 35mw Modified Leadlight Module which throws a great beam out of this handy Little Pointer </font>
<font color="red"> The internals are basically a Chopped Leadlight Pointer Case. I cleaned away the black paint and fitted a tight Aluminum Heat Sink Outer Jacket over the front section, the front is a machined Acetal Cap with Rubber Seal and the mid section is a Black Acetal Sleeve, fitted on the rear is an Aluminum end cap. </font>
<font color="red"> This Modified Laser takes 2 x 1.5 Volt E90 Batteries, they fit perfectly into the inner tube (without inner plastic sleeve). They are half the length, cheap and easy to find at your local store, this is the key to a handy palm size powerfull Laser </font>
<font color="red"> Again I intend to make this Laser Water and Dust Proof and the materials used will make it very robust </font>
<font color="red"> This should give you an idea of size compared to the E2e and 6P Laser Mods </font>
Now to choose a name for this little stick of green Dynamite /ubbthreads/images/graemlins/smile.gif
BTW its only at prototype stage so when I have more time to work on it I will add a switch and Rubber Seals also do a run time test on these batteries. I plan to use the existing Switch on the Module and fit an external push button on the collar, I also plan to machine the end cap so a Lanyard can be fitted.
