with one li-ion per luxIII , you get slight overdrive, with about any of the Vf thingees, hot off the charger, even the higher ones.
will you have a cutoff too??? if you use a boosting type driver, you could discharge your li-ions "to far".
protected cells, or a driver that cutsoff will fix that.
ya see with 2 in SERIES, you can get cell imbalance.
being a cheapskate myself, that is why i DD, use LUXIIIs, have good heat removal, because they match so well.
so are you screwed? or just out of regulation, and a bit brighter for a while /ubbthreads/images/graemlins/grin.gif
