Starting a new post just for this design.
It is nearing completion and I have finished RUN503 (RUN5XX) Where XX is the actual configuration of collected data.
My design notes can be found on my web page at:
LM2621 Desgin Notes.
Here is the run data in case you don't want to look at the web site.
NOTES: CVTR = DC/DC Power dissipated by Converter board (ICs, diode, inductor etc).
Blink = IC hit die thermal limit and shuts down, cools, turns on, heats up and cycles this over and over at several times per second blinking the LS.
Possible Specifications:
Vin-min ~4V
Vin-max ~6V
Output Current adjustment range: 100mA - 750mA
Form factor - Target 17mm circular. (123 battery diameter)
Components: All on one side.
Board Construction: All traces on top side:
Bottom side: Solid Copper (GND).
Component cost: Total <$10.00
Board Cost: ~1.00 in low volume.
First run: Double sided plated thru holes, no silkscreen, no solder mask, tin plated both sides.
Code:
Vin-min ~4V
Vin-max ~6V
