Jetbeam
Results 1 to 6 of 6
Thread: i want to focus my thor for longer throw...
    Default i want to focus my thor for longer throw...
    can this be done? could such an aftermarket reflector be had? does one exist?
    Flashaholic* MaxaBaker's Avatar
    Dec 2004
    South Jersey
    Default Re: i want to focus my thor for longer throw...
    I think the easiest thing for you to do would be to move the bulb up or down in the reflector and see which way focuses it better. Then, if you dont want to spend much money, just find some kind of makeshift spacer that can hold the bulb in place where you want it.
    Concentrate and heave [img]/ubbthreads/images/graemlins/crackup.gif[/img] [img]/ubbthreads/images/graemlins/crackup.gif[/img] [img]/ubbthreads/images/graemlins/crackup.gif[/img]
    I have a 1 tenth inch thick spacer that Iron Man made and sold for 3 dollars.
    He did a couple of runs and said that was all. It works well.
    the ID is 1 3/8" and the OD is 1 5/8"
    I took some pics and posted them about a week and a half ago showing a stock Thor and a Thor with a spacer and a 15 MCP Thor.
    If you are interested, you can follow the link below.
    Spacer in Action
    Oct 2004
    Bonner Springs, KS
    Suggestion for the spacer, the ID and OD match very close to
    1 1/4 inch pipe size. Visit you local hardware store, buy a pipe nipple in steel or pvc, and slice up a few..... [img]/ubbthreads/images/graemlins/grin.gif[/img]
    Apr 2005
    New Jersey USA
    Will the PVC material survive the operating temperatures
    in the bulb socket area??
    gchand
    Oct 2004
    Bonner Springs, KS
    Hmmm, would sure want to check that with infrared temp gun or contact thermocouple maybe, I wouldn't put pvc in if subject to more than 160f or so. Also possible to use 1 1/4 inch ridgid aluminum conduit for the spacer.
