<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Someguy:
Are there any chargers actually designed for NiMH AAs?
Most chargers I've seen (actually all) charge both NiCd and NiMH and use negative delta to terminate the charge. Of course this works fine for NiCds but NiMH's have a much smaller drop thus being much harder to detect.
Is there a charger out there with some sort of temperature sensor?<HR></BLOCKQUOTE>
I can only speak for the Ncd/Nimh Saitek/CCrane combo charger.
The reason I'm posting is becos I've noticed on
both of those chargers something really interesting to me.
As you mentioned, a Hydride cell is harder for the charger to detect as fully charged. This is evidenced by the chargers (only with Nimh cells), that the charger will stay in "top-off" mode occasionally (reduced current as shown on the voltmeter) for quite a while compared to a similar capacity Nicad.
IMO-owners of these two very similar chargers should note:
My solution for this problem turns out to be very simple:
I simply open and re-close the door of the unit...-which will start the whole sequence of charge all over again, but the unit will then
rapidly cycle through the soft start->main charge->top-off->finish/trickle modes to completion-usually in less than 10min
-This little trick seems to work for me with these units every single time, -when the unit gets a little confused about when a charge should have been finished.
