I find that 5 mm. LEDs has inferior tint and beam quality compared to Luxeons, at least the ones I've seen. Why is the beam blue in the middle and more yellow at the edge? It must be because the phosphor layer isn't as good or evenly deposited as in Luxeons. I'm not so sure about the longevity of these emitters either, because they tend to burn of the phosphor, thus worsen the tint. This may not be the case for all 5 mm. LEDs, but the ones I've tried all got bluer as time passed. I have some of them running day and night (20 mA) in a fixture illuminating a small art piece in my living room. I have to change them every couple of month, to keep the light reasonably white.
I for one am not going to buy more lights with this type of emitter other than microlight or picolight style key chain lights, and with lights like JIL DD, Orb RAW, TnC N-cell and others, I don't understand why one would go for expensive lights fitted with 5 mm. LEDs (like Peak or Arc). OK they are a bit cheaper, but not by that much. Can the use of 5 mm. LEDs be justified by a higher efficiency? This would be a good reason to use them of course, but aren't Lux I as efficient at the same low current?
What are your thoughts?
Jan
Jan
