Maxpedition
Results 1 to 2 of 2
Thread: Q-III dual stage problem/How to disable for POP2
    Flashaholic* MorpheusT1's Avatar
    Mar 2005
    Norway
    Default Q-III dual stage problem/How to disable for POP2
    Hi!
    I have a problem with my Modded Q-III.
    I have just bought one POP2 sammie for it,and want to disable the dual function...
    What i have done so far is removing the resistors and shorting out the extra pin that is located one the dual stage switch.
    Since the original ones only have one i figured that would be a good idea.
    But Nooo..
    The light now needs three clicks to turn on....
    And then i can use the UI,but the UI is all Goofed out with the dual stage switch.
    It worked perfectly when the Orignal switch was working,that one shoted out though [img]/ubbthreads/images/graemlins/frown.gif[/img]
    Any suggestions what to do?
    Thank you,
    Benny
    Dec 2004
    Toronto, Canada
    Default Re: Q-III dual stage problem/How to disable for PO
    Well, I would remove the resistors and shorting the two pads out. If you look at a original switch, that is how it was. I wouldn't go about shorting out the pins. Hope that helps.
