I won this headlamp on ebay for $9.50. The LED has an output similar to my minimag with madmax plus. Runs on 3 AA batts. package says up to 30 lummens but i don't have a light meter to verify it. there are 4 modes 100%, 50%, 25% & flashing. from the instructions it can run 3 hours at 100% but i haven't tested it out yet.
The light is activated by pushing a rubber covered switch. Pushing it once turns it on at 100% and then pressing it again cycles through the modes. to activate the flashing mode press and hold the button for 3 seconds.
The head pivots, with a plastic lip engaging plastic ridges to hold position. Kind of noisy and cheap sounding, but it will probably hold up fairly well.
overall a good deal for under $10.
contents
cyclops (100%) vs madmax plus vs 8 led xnova
cyclops (25%) vs madmax plus vs 8 led xnova
madmax at 10 ft
cyclops 100% at 10 ft
cyclops 25% at 10 ft
battery indicator
contents
madmax at 10 ft
battery indicator
