AtomSphere
Multi type Li-ion Charger\'s adaptor replacement
Also known by some as the DSD charger shown here Charger
The original adaptor is spoiled. Now i am using my Nokia handphone charger's adaptor to replace it. The charger is still a protected charger because the circuitry is built into the charger and not the adaptor
Original Adaptor's Specs : 5.5v 350mA - chargetime of Protected R123 (750mAH) is 1hour 20min
Nokia Adaptor's Specs : 5.3v 500mA -
Pila charger's specs : 4.6v 1.5AX2
Recommend me a spec or adaptor that i can use that can safely charge a 750mAH R123. It needs to be able to handle both 110v and 230v. I need a higher output adaptor because i usually charge 18500 and pilas and it took very long to get them charged up. Just worried that i get a adaptor too high powered for the R123 and worried it cannot take it.
I like something like the Pila's charger's speed.
