Sold/Expired FS: DIY FLuPIC v2.1 Converter JIL 1.3W Mods! Pics!
goldserve
Toronto, Canada
I have a limited number of brand spanking new FLuPIC v2.1 converter boards.
Let's start with the firmware features itself.
FLuPIC v2.1:
-User adjustable LOW level
-User adjustable HIGH level
-Burst level up to 1.2A
-User adjustable strobe frequencies from 4hz to 15hz
-5 user modes available
*Defaults in firmware: Low (3/20), High (15/20), Strobe (10hz), User Mode 1
Please refer below for the userguide:
Board information:
-0.6" (15.2mm) in diameter
-0.068" (1.72mm) board thickness
-0.14" (3.53mm) board thickness including tallest component
-0.26" (6.66mm) in diameter of battery contact pad on the back
-0.06" (1.5mm) in diameter of screw holes
-0.47" (11.91mm) from center to center of screw holes
Battery configurations:
The following combinations will work but not have stressed fully at some configurations.
1 x 4.2V Li-Ion
3 x 1.2V NiMh
4 x 1.2V NIMh
3 x 1.5V Alk
1 x Pila (Volts???)
2 x CR123 (this is absolutely the max! I can install a resistor 1 ohm resistor to ensure 0.4V is dropped)
I am offering boards soldered and the required posts to solder it to the JIL emitter board. Contact me for details. I am selling these kits for $30. I can offer my modding servies for only $40 complete with international shipping included.
Other possible uses is to hook up the converter board and put into cans like the Q3. The possibilities are limitless!
goldserve
Toronto, Canada
Re: FS: DIY FLuPIC v2.1 Converter JIL 1.3W Mods! P
The max reconmented Vin is 5.5V but if you choose to use two CR123s, I can put an additional resistor for max Vin of 6V
StoneDog
Suwanee, GA
It that's the case, and this can be put into a QIII mod, could it also be put into the 2x123 version of the Q3?
goldserve
Toronto, Canada
Yes, I believe it will work if I put a resistor for safety measures. Just to drop 0.3 V off the 6V. Let me go home and work out the numbers.
Sengoku
Eng, UK
Any chance of a custom made copper/alu heatsink(virens?) coupled with FLuPIC for the jil 1.3? because it will become SO HOT SO Quickly driven at 1200mA(burst)
Also it really seems like wasted space between the board and emitter(about 10mm?) that could potentially be extra heatsink.
insufficient heatsink is the only thing stopping me from buying this very cool convertor!
Please count me in if these are available!
Alan
goldserve
Toronto, Canada
Is is for the JIL or Q3 you are asking for? I will talk with viren to see what he can make. Thanks.
Sengoku
Eng, UK
Yepp,im asking for the JIL, thanks for considering my request!
