Sidebar, but Chauvet's Q-spot 260 moving head is powered by a CST-90.
Haven't seen one in action, but reviews put it in the same ballpark as 150watt discharge.
In a compact plastic fixture we can se how jtr1962's tests are so critical.
Which bin of the NS6L183 will you be testing? I used one in this build and I like it a lot.
Will
Information here is very valuable, thanks.
jtr1962, could you mind to explain a bit on how you convert the lux reading to lumen? I looked into your spreadsheet and it seems very complicated and I'm not quite understand. Thanks.
Remember 1lux=1lm/m2
So you basically add the lumens back, integrate. Now the finer you go dividing an area, the better. I guess jtr also uses symmetry in led patterns to cut down on sampling.
Subscribing this. Very valuable info.
Thanks
