The question has oft come up: "How do I split a 223? Is it hard?" So I will now present to you how I split 223s. Others do it other ways, and you may do it your own way too...but this should get you started.
Todays victom? A Duracell DL223.
I like to go for the "cap" if you will, where the plastic shell for the 2 CR123s is capped. ON the DL223s it is at the end of the words...you'll see in the photo. If you look *real* hard you might even be able to see the seam.
I have a miniature hack-saw <Imagine Photo here> that I use to cut into the battery just a bit...
Once I've cut in a bit I take a screwdriver or other flat, blunt object (A putty knife would probably also work well) and pry the cap off. At this point you'll see the ends of the 2 223s, attached by a narrow metal band. Push the batteries out of the plastic container...I like to do it by pushing on the tops of the batteries through the holes in the top of the plastic case.
At this point the 2 CR123s will pop out. Be careful!!!! If they touch they will spark...notice how I've changed backgrounds on this next pic, it's because all the other photographs were taken on the side of a computer case...metal conducts electricity..
Pull the 2 batteries in opposite directions. The metal band will pull of one battery and stick to the other. Usually it will pull off the positive tip of battery "A" and stay on the neg end of battery "B." Just use some pliers to carefully pull it off the other battery. It sholdn't be too tough...
Then wrap the battery. I use masking tape because it is plentiful around my house. I put 2 strips on, one curls around the top edge of the battery and goes about half way down the batt. THe second strip meats up with that one and finishes off the job, wrapping slightly around the bottom of the battery.
So there you have my way of splitting CR223s. I am sure there are more efficient methoods, but this should get you started.
Good luck!
Good luck!
