Olight - PL - MINI
Results 1 to 5 of 5
Thread: New POP2E v2.38 Samnmies
    Jan 2004
    tennesse, usa
    Thumbs up New POP2E v2.38 Sammies,
    I have 5 TWOH POP2E version 2.38 for $59.95 shipped anywhere.
    paypal address: roberto.roxas@comcast.net
    CC funded PP please add 4%: cgpeanut@gmail.com
    In a nutshell the POP2E v2.38 has the following features.
    UI-1 = user - high - set - r.strobe (default UI)
    UI-2 = low - user - high - strobe
    UI-3 = high - user - r.strobe
    UI-4 = low - user - high - strobe - sos - throb
    UI-5 = low - user - high - r.strobe - sos - throb - set
    r.strobe is semi-random speed strobe
    throb well I can describe as a beacon? or if you have a glo-toob then you know what I mean
    EDIT: We are preparing a flowchart on how to change the UI.
    I'll post some videos tonight.
    Last edited by cgpeanut; 09-01-2005 at 12:48 PM. Reason: spell checking as always, add a diagram here
    cgpeanut
    Innovate not imitate.
    Jan 2004
    tennesse, usa
    Talking Re: New POP2E v2.38 Samnmies
    Here's the POP2E v2.38 in action!
    I'm halfway clicking to move to the next setting and also to set.
    A lot better and faster but most importantly less effort. With
    basically two settings user, and high, it's super simple and practical.
    Last edited by cgpeanut; 08-31-2005 at 07:51 AM. Reason: not UI but two basic settings now it makes sense
    cgpeanut
    Jan 2004
    tennesse, usa
    Default Re: New POP2E v2.38 Sammies TWOH
    4 left,
    Alan, Your JiL PIL is packed and will be ship this morning.
    cgpeanut
    May 2001
    Beachwood, Ohio
    Default Re: New POP2E v2.38 Samnmies
    Do these use 1 LDO or 2? Burst mode? What is max target current?
    Jan 2004
    tennesse, usa
    These are single TPS73601 LDO's
    I can custom build you one with dual LDO if you like, TPS73601 as primary and tps73101 as secondary with TWOH. IIRC I measured 550mA output a while back with a TYAH. I have to dig up the graphs but do a search on POP2 you might find the answer there.
    I built a "burst mode" version for my Q3 wherein the secondary LDO was replaced by a p-fet for direct drive. had to do some pcb mod to achieve this, along with custom software DJ created, The lux started degregating after only 10 hours of use and gets hot quickly and that's on a Q3 with ViRen''s copper heat sink , sammie version cannot handle the heat fast enough I think, On the Q3 I can replace the lux easily not so on the sammie. As far as brightness compared a regular POP2 TWOH with tps73601, I can't tell.
    cgpeanut
